16 years agoBuffer Overflow and Underflow in Clocked Video Input/Output
Hi I am designing a video system to buffer three HD 1080p video stream. The input is in RGB 4:4:4 format at 148.5MHz. Output is also the same. I am using Quartus 9.0 SP1. The system for ...
16 years ago --- Quote Start --- The system for single HD stream consists of CVI, Frame Buffer and CVO block. Three such blocks are cascaded serially. --- Quote End --- Are you attempting to do three 1080p frame buffers at the same time? This would require a lot of memory bandwidth. Assuming standard 1920x1080p60, the total horizontal width is 2200. This means you need to maintain a rate of 1920/2200*148.5=129.6 Megapixels/second in and out of the memory for each frame buffer. If you have three frame buffers, this is a total of 777.6 Megapixels/second. How many bits per pixel are you doing? How wide is your memory bus? Is anything else using the memory?
