TSchu3
2 years agoBoard Skew Parameter Tool Causes Excel Error
Hello the Board Skew Parameter Tool version 1.0 dated 1-26-2019 https://www.intel.com/content/www/us/en/content-details/652693/board-skew-parameter-tool.html Is not compatible with the version o...
Farabi_Altera
2 years agoHello,
This tool only supports : Stratix 10, Arria 10, Cyclone 10 devices.
regards,
Farabi
TSchu3
2 years agoThanks.
If it only supports those devices then what is the purpose of the UniPHY IP tab? The note next to it is clearly swapped with the note above it.
The Cyclone 10 tab should have the note about "Cyclone 10 External Memory Interfaces IP-Board Skews"
The UniPHY IP tab should have the more generic "UniPHY External Memory Interfaces IP- Board skews" note.
And the UniPHY IP tab is still broken no matter what chip you intend to use it for.
