11 years agoBFM Read from On Chip RAM
I followed D. W. Hawkins ([email protected]) tutorial on JTAG-to-Avalon-MM. There is a task in the tutorial that reads a slave address using the BFM master. The slave is onchip_ram. The problem is...
11 years agoOkay, I got it. This on-chip RAM does not have both waitrequest and readdatavalid. It works on a pre-determined read latency. But as you said, the interconnect takes care of it:
onchip_ram (
.clk (clk_clk), // clk1.clk
.address (mm_interconnect_0_onchip_ram_s1_address), // s1.address
.clken (mm_interconnect_0_onchip_ram_s1_clken), // .clken
.chipselect (mm_interconnect_0_onchip_ram_s1_chipselect), // .chipselect
.write (mm_interconnect_0_onchip_ram_s1_write), // .write
.readdata (mm_interconnect_0_onchip_ram_s1_readdata), // .readdata
.writedata (mm_interconnect_0_onchip_ram_s1_writedata), // .writedata
.byteenable (mm_interconnect_0_onchip_ram_s1_byteenable), // .byteenable
.reset (rst_controller_reset_out_reset), // reset1.reset
.reset_req (rst_controller_reset_out_reset_req), // .reset_req
.address2 (mm_interconnect_0_onchip_ram_s2_address), // s2.address
.chipselect2 (mm_interconnect_0_onchip_ram_s2_chipselect), // .chipselect
.clken2 (mm_interconnect_0_onchip_ram_s2_clken), // .clken
.write2 (mm_interconnect_0_onchip_ram_s2_write), // .write
.readdata2 (mm_interconnect_0_onchip_ram_s2_readdata), // .readdata
.writedata2 (mm_interconnect_0_onchip_ram_s2_writedata), // .writedata
.byteenable2 (mm_interconnect_0_onchip_ram_s2_byteenable), // .byteenable
.clk2 (clk_clk), // clk2.clk
.reset2 (rst_controller_reset_out_reset), // reset2.reset
.reset_req2 (rst_controller_reset_out_reset_req) // .reset_req
); altera_merlin_slave_translator# (
.AV_ADDRESS_W (7),
.AV_DATA_W (64),
.UAV_DATA_W (64),
.AV_BURSTCOUNT_W (1),
.AV_BYTEENABLE_W (8),
.UAV_BYTEENABLE_W (8),
.UAV_ADDRESS_W (32),
.UAV_BURSTCOUNT_W (4),
.AV_READLATENCY (1), <---
.USE_READDATAVALID (0), <---
.USE_WAITREQUEST (0), <---
.USE_UAV_CLKEN (0),
.USE_READRESPONSE (0),
.USE_WRITERESPONSE (0),
.AV_SYMBOLS_PER_WORD (8),
.AV_ADDRESS_SYMBOLS (0),
.AV_BURSTCOUNT_SYMBOLS (0),
.AV_CONSTANT_BURST_BEHAVIOR (0),
.UAV_CONSTANT_BURST_BEHAVIOR (0),
.AV_REQUIRE_UNALIGNED_ADDRESSES (0),
.CHIPSELECT_THROUGH_READLATENCY (0),
.AV_READ_WAIT_CYCLES (0),
.AV_WRITE_WAIT_CYCLES (0),
.AV_SETUP_WAIT_CYCLES (0),
.AV_DATA_HOLD_CYCLES (0)
) onchip_ram_s1_translator ( I just ran the simulation on ModelSim and traced the waitrequest=0 and readdatavalid=1 signals generated by the Avalon translator connected to this on-chip RAM. The readdatavalid is produced properly the next clock cycle when data is ready to read but the BFM master still reads the previous clock cycle :confused:
