14 years agoBasic IP Question
I have a design that uses the Nios II core. I contacted a rep about the need to license this bit of IP and he said that if I used the "e" version then there is no license fee; other wise it is $495....
14 years ago --- Quote Start --- did you regenerate the SOPC/Qsys system after changing the Nios to /e? simply recompiling in Quartus will not complete the change --- Quote End --- I did. It still gives the "time limited" message, though the time is unlimited. The programmer pop-up window must still be open for the code to run. Are you sure it is the nios core? I am also using on-chip memory, jtag uart, serial uart, system id, and parallel IO. Thanks for the help Rich
