14 years agoBasic IP Question
I have a design that uses the Nios II core. I contacted a rep about the need to license this bit of IP and he said that if I used the "e" version then there is no license fee; other wise it is $495....
14 years ago --- Quote Start --- the -e no longer required a license as of 10.0 or so. using older versions would require a Nios II license indeed, that's the Nios core causing the Time Limited behavior: 6AF7_00A2 Nios II Embedded Processor Encrypted output --- Quote End --- OK that is good news. Any idea why I still get the time limited message/behavior after switching the nios type to /e? Thanks Rich
