14 years agoBasic IP Question
I have a design that uses the Nios II core. I contacted a rep about the need to license this bit of IP and he said that if I used the "e" version then there is no license fee; other wise it is $495....
14 years agothe -e no longer required a license as of 10.0 or so. using older versions would require a Nios II license
indeed, that's the Nios core causing the Time Limited behavior: 6AF7_00A2 Nios II Embedded Processor Encrypted output
