Avalon Transaction Responses & Bridges
- 2 months ago
That was the reason, why we tried the response interface. I also expected the response codes to be propagated back to the master. But when I understand you correct, the Avalon response only works on a single interconnect and is not useable across bridges ist that correct?
Yes, your understanding is correct.
Can you don't use the bridge? Master get the response from slave?
Hi Sheng, thanks for the update,
We tried the variant by holding waitrequest until a write command is fully processed already. However that does not work in case of pipeline bridges in between either, since e.g. for single word writes, the bridge accepts the write right away before the slave is triggered, due to its pipeline stage. Hence the initiating Master has also no control, when the write is actually processed at the slave side. ==> so that is not working either.
best regards
Fabian
- FabianL2 months ago
In parts of the design this is an option. But the relevant parts are in a QSYS subsystem, which requires a bridge to have a single Avalon Slave port at the interface. Otherwise all Avalon-MM Slave Ports of the subsystem are exported individually, causing a real mess in the interface (we are talking about 5-10+ slave ports).
So I guess we have to implement a independent handshaking mechanism on top of Avalon.
Thanks for your explanations.
