FabianL's avatar
FabianL
4 months ago
Avalon Transaction Responses & Bridges
Hello I have a question about the behavior of Avalon-MM Pipeline Bridges concerning the response signals. I have the following setup: 2 (or more) Avalon-MM Masters Master cmd_ctrl (supports Aval...
  • ShengN_altera's avatar
    ShengN_altera
    3 months ago
    That was the reason, why we tried the response interface. I also expected the response codes to be propagated back to the master. But when I understand you correct, the Avalon response only works on a single interconnect and is not useable across bridges ist that correct?
    Yes, your understanding is correct.
    Can you don't use the bridge? Master get the response from slave?
