11 years agoAvalon Streaming sink and source state machines
Hello to all, I am facing the problem to code a state machine that select some data from an avalon streaming source. Selected data will be sent to another avalon streaming interface. I don't ...
11 years agoAltera documentation is notoriously bad, at least in my experience. So try reading the latest versions of documentation.
Avalon streaming data is sampled on rising edge as is shown in your figure. Which part seems no compliant? Is it the FSM part? Seeing as you are trying to make a Moore state machine you would have 2 state (state1, state2) and transitioning between these states depends on your input X. To do this you need first sample your stream and store the value into reg X. Then your FSM would transition based on your X changing. The first part will be the same as before: wire [width-1:0] d; reg [width-1:0] X; assign d = data_in; always @(posedge clk) begin if (snk_valid) begin X<= d; end end Then we need to define the FSM: a) define state and next_state reg [1:0] state (since you have two states 01 and 10) reg [1:0] next_state parameter state1 = 2'b01; parameter state2 = 2b'10; (just assigning values to our state names) b) define how the FSM changes state. Here we use the combinatorial always block: always @( state or X) //our sensitivity list is state or X next_state = 0; case(state) //now we look at what state comes next state1: //lets say that if X = 0 then we keep the same state, if X = 1 we go to state2 begin if( X == 1 ) next_state = state2; else next_state = state1; end state2:// same idea for state2 if (X == 1) next_state = state1; else next_state = state2; end endcase end c) We defined next_state so we have to update state always @(posedge clk) begin state <=next_state end d)Now we define what to do when we are in each state. Since we are outputing an avalon stream we want this to be clocked and i guess in sync with the incoming valid signal reg dout; always @(posedge clk) //clocked process begin if (snk_valid) begin //sync signal to valid of input case(state) //again we will do a case statement for the states state1: dout <= "Some output" state2: dout <= "Some other output" default: dout< = 0; endcase end end -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- So you see we have 4 subsections: 1) sample incoming data 2) define transitions of FSM states 3) update current state 4) define functions during each state Let me know if these looks reasonable
