11 years agoAvalon Streaming sink and source state machines
Hello to all, I am facing the problem to code a state machine that select some data from an avalon streaming source. Selected data will be sent to another avalon streaming interface. I don't ...
11 years agoSampling streaming data is easy since it is synchronous to the clock. In an always block with the condition of posedge clk, you would check if your valid signal is asserted. Then you would read the data.
Something like this wire [width-1:0] d; reg [width-1:0] dout; assign d = data_in; always @(posedge clk) begin if (snk_valid) begin dout <= d; end end You can add reset (negedge rst_n) to make the logic more robust. For the FSM you need to set up your state machine in a combinatorial always block. It is similar to the one above (which is sequential) but instead of using the clock as your condition (sensitivity list), you will use state and the regs that affect your state. In this always block you will determine next_state based on current state and changes in your sensitivity list regs. Then you will need a second combinatorial always block that describes what to do when you enter each state (this is done by using the case statement). This link has a good overview of FSMs in verilog: http://inst.eecs.berkeley.edu/~cs150/sp12/resources/fsm.pdf
