Avalon Streaming Dual Clock FIFO
- 1 year ago
Understood that. Could you try to use the simple adapter ST handshake clock crosser under the bridges and adapters section? I think you're connecting it correctly previously. Instead of using dual clock fifo under on-chip memory section, as it's embedded peripheral I'm not sure is there anything needs to take note when using it.
Regarding why booting slow when using 200mhz, you need to open a new thread target pcie to get the related pcie expert helps.
Sheng
Another one will be using Avalon Streaming Handshake Clock Crosser IP.
Hi there @ShengN_Intel
Thanks for this suggestion!
Do you know where the docs are for this IP - all I can seem to find is this?
May I ask if this is to be used as followed:
And if so - how does this IP manage data transfer?
