13 years agoAvalon-ST Test Pattern Generator and Checker
I designed my custom Avalon-ST peripheral and would like to test in on my FPGA. I found Altera's Avalon-ST Test Pattern Generator and Checker IPs and would like to use them in my tests. I try to generate packets(!), but nothing happens. At the end I connected Generator with Checker direct and looked with SignalTap on my Avalon-ST bus, but nothing was there. For initialization I use Altera's API commands in this order: data_source_reset(0x5000880) ; data_sink_reset(0x5000860) ; usleep(1700000) ; data_sink_init(0x5000860) ; data_sink_set_enable(0x5000860, 0x1) ; usleep(1700000) ; data_source_init(0x5000880, 0x5000890) ; data_source_set_enable(0x5000880, 0x1) ; usleep(1700000) ; The addresses are defined in system.h: # define SINK_0_BASE 0x5000860 # define SOURCE_0_COMMAND_BASE 0x5000890 # define SOURCE_0_CSR_BASE 0x5000880 What am I doing wrong? How should I start the packet generator? This problem tortures me the whole weekend. Regards, Linas1 Reply
I solved it:
data_sink_init(SINK_0_BASE); data_sink_set_enable(SINK_0_BASE, 1); data_source_set_enable(SOURCE_0_CSR_BASE, 1); data_source_send_data(SOURCE_0_COMMAND_BASE, 1, 64, 0x03, 0, 0); With these commands I am able to generate the needed packets.
