17 years agoAvalon ST Interface Help Pleaseee
Hello All, How are you? Finally after great help from Jake and thiago on this forum , I have been able to chalk out my video out interface. But now I am having problems in interfacing my custom...
17 years agoHello Jake , Thanks again for your quick response.
Yes the three stripes are Vertical , The RGB Values I am sending are 255,128,64 and the colors are Dark Green, Dark Redish and Dark Blueish. Yes I have made sure that the block is rd latency of one but yet cant figure out where the problem is. I also checked if the sop and EOP come at the write symbols. Also checked the whether the symbols are right. You must be right it is shifting a pixel a frame.. But how do i figure out where ? is there any good way of checking if my avalon st block is working correctly? I am just trying the Test checker block , but not to sure how it will know what data I am sending it and that whether it is right and how many symbols it should expect. thnking you nadeem jamal
