10 years agoAvalon On chip Fifo
Hi all,
i'm having trouble with avalon Fifo core (dual clock mode). I have a simple FSM that grabs data from a fifo(1) and then transmit the response to another fifo(2) but nothing is written as read level is 0. But, if i write 3 times the same data in fifo(1) i get one response in fifo(2). well i think i missed something there... notes : interrupts are disabled, Almost empty = 1init_fifos_in(); init_fifos_out();
init_fifos_in();
init_fifos_out();
altera_avalon_fifo_write_fifo(FIFO_PC_TO_DIF_IN_BASE, FIFO_PC_TO_DIF_IN_CSR_BASE, 0x00004005);
printf("pio read = x%x\n", IORD_ALTERA_AVALON_PIO_DATA(PIO_0_BASE));
if(altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE)>0)
printf("altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE) = %d\n",altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE));
while(altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE)!=0)
printf("fifo read = x%x\n", IORD_ALTERA_AVALON_FIFO_DATA(FIFO_DIF_TO_PC_OUT_BASE));
status initializing fifo = 0
pio read = x4005
altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE) = 1
fifo read = x30c30c301 Reply
problem solved, fsm did not work properly (signal tap), although it was ok in simulation...
