Avalon-MM to PCIe address translation table settings
- 2 years ago
Hi BobSD,
From what you provided compared with the user guide. It is seen to be correct.
But I cannot 100 % confirm that as it is your custom design.
As you are using a single MSGDMA.
What alternative you can do to double confirm is to refer to the design example provided in the previous post.
Set the parameter accordingly and monitor if you are able to get the desired output/result.
Let me know if there is any other things I can help you.
Regards,Wincent_Intel
Final update:
We were never able to get address translation to work so I changed the PCIe Avalon-MM address setting from 32 bits to 64 bits.
From this:
To this:
This change eliminated the Avalon to PCIe address translation and the DMAs into external CPU memory across the PCIe bus began to work immediately.
