MateusSoares
3 years agoAvalon MM slave component: readdata signal is always zero
I have this simple Avalon MM slave component where I set avs_s0_readdata to a constant value:
But avs_s0_readdata always stays with value zero. I've tried to achieve this in three different ...
sstrell
3 years agoYour clk is not toggling according to Signal Tap, so a better question may be how the writes are working!
