MateusSoares
3 years agoAvalon MM slave component: readdata signal is always zero
I have this simple Avalon MM slave component where I set avs_s0_readdata to a constant value:
But avs_s0_readdata always stays with value zero. I've tried to achieve this in three different ...
RichardT_altera
3 years agoDo you see the same behavior when you try to simulate the design?
Btw, may I know which Quartus edition and version are you using?
Which device are you using?
Richard Tan
