14 years agoAvalon_ mm_ master wrapper (vhdl)
Hello, I have written a code for CDMA Encoding and CDMA Decoding using VHDL Language. Now i have to create as a custom IP using component editor.Here i want a help regarding the avalon signals. ...
14 years agofor reading....
if avs_m0_read='1' then
avm_m1_read<=avs_m0_read;
avm_m1_address<=avs_m0_address;
--avm_m0_waitrequest<='1';
avs_m0_waitrequest<='1';
end if; for writing..... PI_WRAP_EN,PI_WRAP_DE are cdma encoding and decoding port maps. here i didnot add byte enable . if avs_m0_write='1' then
avm_m1_write<=avs_m0_write;
avs_m0_waitrequest<=avm_m1_waitrequest;
PI_WRAP_DE<=avs_m0_writedata;
avm_m1_writedata<=OUTPUT_WRAP_DE;
end if; is that read and write operations are correct. Tell me sir, Read and write should be '0' or '1' to start operation. thank you very much in advance.
