14 years agoAvalon_ mm_ master wrapper (vhdl)
Hello, I have written a code for CDMA Encoding and CDMA Decoding using VHDL Language. Now i have to create as a custom IP using component editor.Here i want a help regarding the avalon signals. ...
14 years agoDear K_J,
I got the solution for address range problem.what ever is the slave address range(8 bit or 4 bit),master range must be atleast 32bit width.at this point master will use the byteenable signal,if not master will write spuriously into the slave. now, can you tell me , how to use the byte enable signal in the master port, any example code in vhdl. Thank you K_J.
