14 years agoAvalon_ mm_ master wrapper (vhdl)
Hello, I have written a code for CDMA Encoding and CDMA Decoding using VHDL Language. Now i have to create as a custom IP using component editor.Here i want a help regarding the avalon signals. ...
14 years ago --- Quote Start --- my custom logic does not store any thing,it does not have any registers . what ever the input it gets, it just encodes and gives out put. the ports are before encoding: address:8-bit data:32 bit after endoding address : 4bit data 16bit after decoding address:8bit data:32bit how to know that address range? thanks. --- Quote End --- You've lost me. On the one hand you say that there are no registers but then you talk about 8 bit and 4 bit addresses. Which interface is generating the addresses (i.e. who is the Avalon master) and who is expected to receive them (i.e. who is the Avalon slave)? Can you map these to the blocks in the processing chain that you previously described and maybe sketch something out so it is clearer what interface has which addressing? Kevin Jennings
