14 years agoAvalon_ mm_ master wrapper (vhdl)
Hello, I have written a code for CDMA Encoding and CDMA Decoding using VHDL Language. Now i have to create as a custom IP using component editor.Here i want a help regarding the avalon signals. ...
14 years ago --- Quote Start --- - NIOS does not support 32 bit address space, only 31 bits. The slave interface needs to cut down by at least one bit...likely more since if you have a 31 bit slave device connected to the NIOS, then it will consume the entire address space, leaving no address space for anything else...such as memory to read the software program. --- Quote Start --- - Does the slave interface of 'CDMA_ENCODING' really have 2^32 addressable memory locations? That's an awful lot. How many registers/ports are really addressable? That will define how many bits wide the address bus needs to be. --- Quote End --- Kevin Jennings --- Quote End --- my custom logic does not store any thing,it does not have any registers . what ever the input it gets, it just encodes and gives out put. the ports are before encoding: address:8-bit data:32 bit after endoding address : 4bit data 16bit after decoding address:8bit data:32bit how to know that address range? thanks.
