14 years agoAvalon_ mm_ master wrapper (vhdl)
Hello, I have written a code for CDMA Encoding and CDMA Decoding using VHDL Language. Now i have to create as a custom IP using component editor.Here i want a help regarding the avalon signals. ...
14 years agoDear sir,
I have created the Custom component of CDMA_ENCODING and CDMA_DECODING as per Mr.Kevin Jennings suggestions. NIOS-->(S)CDMA_ENCODING(M)-->(S)CDMA_DECODING-->slave Now , while building my own system in SOPC builder. i added components in this order. NIOS ONCHIP MEMORY CDMA_ENCODING CDMA_DECODING SLAVE(SD RAM). I am getting these errors: cpu_0:nois ii instruction master cannot address memories over 2^32.cpu_0:nois ii data master cannot address memories over 2^32.
memory map cannot fit within the addressable memory space of the nios ii data master which is restricted to 31 adress bits.. my both address and data masters are 32-bit only. what is the cause of this error, and suggest me the possible solution . thank you.
