14 years agoAvalon_ mm_ master wrapper (vhdl)
Hello, I have written a code for CDMA Encoding and CDMA Decoding using VHDL Language. Now i have to create as a custom IP using component editor.Here i want a help regarding the avalon signals. ...
14 years agoDear Cris72,
i saw that earlier itself, but the template is in verilog , i am not that much familiar with that code.is there any template in VHDL format sir. main aim of my code is to reduce the No.of lines in required in avalon BUS. So output from NIOS is 32-bit.. i am reducing to 16-bit using CDMA. here i have to connect the output from NIOS to CDMA_Encoding. (32-bit-->16bit), Is this possible to do so. Is there any ready made codes which work as a wrapper. Thank you.
