sadad
7 years agoAvalon Interconnect Dynamic Bus Sizing and Bursts
Hello! My Avalon-MM master has 32bit data width and is bursting capable. Now i connect an Avalon-MM slave with 8bit data width which is also bursting capable. Will a 32bit read or write access to ...
KennyT_altera
7 years agoIs there any steps that I am missing? I am getting error:
# ** Error: (vcom-11) Could not find master_0.altera_avalon_mm_master_bfm_vhdl_pkg.
# ** Error (suppressible): test_program_pkg.vhd(8): (vcom-1195) Cannot find expanded name "master_0.altera_avalon_mm_master_bfm_vhdl_pkg".
# ** Error: test_program_pkg.vhd(8): Unknown expanded name.
# ** Error: (vcom-11) Could not find slave_0.altera_avalon_mm_slave_bfm_vhdl_pkg.
# ** Error (suppressible): test_program_pkg.vhd(11): (vcom-1195) Cannot find expanded name "slave_0.altera_avalon_mm_slave_bfm_vhdl_pkg".
BInos
7 years agohm, must be something on your side, retested my steps without errors.
Did you make sure that:
"Open the qsys design hit "generate HDL" => make sure "Generate Simulation Model" is set to "VHDL"."
NONE would be wrong!
