TR4
5 years agoasmiblock documentation
When generating the "ASMI Parallel II Intel FPGA IP", there is an option to not include the ASMIBLOCK:
"Disable dedicated Active Serial interface" = "Routes the ASMIBLOCK signals to the top leve...
JohnT_Altera
5 years agoHi,
If you are not using the dedicated ASMI block, then it will generate a soft IP that you can connect to the GPIO pin. Please be aware that the flash connected to non dedicated ASMI block cannot be used for configuration.
