10 years agoasmi_parallel mixed simulation
Trying to simulate the asmi_parallel IP in Modelsim. My code is VHDL, IP is Verilog. First attempt resulted in "Unresolved defparam reference to .." error occurring 13 times. Added altera_mf_ver a...
9 years agoHi Paul,
I face a similar problem when I try to simulate a code where I just read the memory capacity ID of the EPCQ128 using Altera ASMI parallel IP core. I get 1 error: Unresolved defparam reference to 'sd4' in sd4.enable_sim. Did you solve your problem? If yes, please specify what changes you made. It'll be really helpful for me. And I'm not using mixed simulation. Everything is in Verilog. Thankyou.
