LSant1
8 years agoArria10 EMIF Design Example Simulation
I generated the design example for Arria10 EMIF. I tried to simulate it following the instructions in the example design user guide. But I get all blank waveforms. Is there any step missing? Am I req...
Vicky1
8 years agoHi Lakshmi,
"Yes, I did that. I only see the clock running. I tried to force the reset and that did not help."
You can force the signals refer the attachment & then run.
First you need to understand the working of EMIF & then you can perform simulation by forcing appropriate signal.
you can also do one thing ,
- Perform "Start Analysis & Synthesis" then
- Processing -> Start -> Start Test Bench Template writer
It will create .vt file Test Bench File under /simulation/modelsim/arria.vt
for simulation, here provide stimulus & that you can use in NativeLink setting
Best Regards
Vikas Jathar
