16 years agoArria II GX refclk pins
Hi there, Is there any assignment I need to set when I use the refclk pins as clk inputs? I am using EP2AGX65CU17C6 device. We connected a differential clock input to pin M19 and M20, which is ...
16 years agoIn top level entity I declared the input signal like:
ref_clk_left : in std_logic; Then in pin planner, as the attached screenshot, I assigned the ref_clk_left signal to pin M19, and set the IO standard as LVDS. I also tried using chip_pin and altera_attribute to do it, but got the same result. attribute chip_pin: string; -- Altera specific pin assignment constraint attribute chip_pin of ref_clk_left : signal is "M19"; attribute altera_attribute: string; attribute altera_attribute of ref_clk_left : signal is "-name IO_STANDARD LVDS"; What did you mean when you are saying clk pins and user io? are you saying M19 and M20 are clk pins, and ref_clk_left is the user io? If that's the case, how do I set the M19 and M20 pins to be LVDS? Thanks, Hua
