14 years agoArria II GX kit + SDI + VIP , only CVI->CVO, CVO no output
Arria II GX kit + SDI + VIP , only CVI->CVO, CVO no output. There are is_clk,is_data,vid_clk,vid_data,vid_data_input,no av_readdata,av_writedata,is_active_line_count_f0,is_active_line_count_f1....
14 years agoHi, Socrates,thank you very much for your reply.
I fixed the design in Qsys.The TPG connect to CVO directly, TPG and CVO no control. If no software control,normally it should be have output,is right? But my CVO no output. TPG parameter is Maximum image width:1920,Maximum image height:1080, Bits per pixel per color plane:10, Colorspace:YCbCr, Output format: 4:2:2 Color plane configuration: Parallel Interlacing: Progressive output Pattern: Color bars The SDI is tested by loopback. It is OK. There are output. From Qsys CVO only have the follows parameter: .sdi_out_1_clocked_video_underflow(), .sdi_out_1_clocked_video_vid_clk(tx_p2_pclk ), .sdi_out_1_clocked_video_vid_data(sdi_tx_data_sopc), .sdi_out_1_clocked_video_vid_ln(sdi_tx_ln_sopc), .sdi_out_1_clocked_video_vid_trs(sdi_tx_trs_sopc) A2gxSDI3G_ch4 u1_A2gxSDI3G ( //common .rst_rx ( reset ), //input .rst_tx ( reset ), //input .sdi_gxb_powerdown ( 1'b0 ), //input .gxb4_cal_clk ( gp_clk ), //input //core config settings .enable_ln ( enable_ln_p2 ), //input [0:0] .enable_crc ( 1'b1 ), //input [0:0] .en_sync_switch ( ), //input .enable_hd_search ( 1'b1 ), //input .enable_sd_search ( 1'b1 ), //input .enable_3g_search ( 1'b1 ), //input //tx inputs .tx_pclk ( tx_p2_pclk ), //input - loopback clock .tx_serial_refclk ( gxb_refclk ), //input - from pcie 148.5 vcxo //.txdata ( fifo_data_p2 ), //input [19:0] .txdata ( sdi_tx_data_sopc), //input [19:0] .tx_trs ( sdi_tx_trs_sopc ), //input [0:0] - not used .tx_ln ( {sdi_tx_ln_sopc,sdi_tx_ln_sopc} ), //input [21:0] - not used //.tx_std_select_hd_sdn ( ), //input //.tx_data_type_a_bn ( 1'b1 ), //input //.tx_std (pclk_74), //.tx_trs ( txtrs_p2 ), //input [0:0] - not used txtrs_p0 // .tx_ln ( {11'b0,txln_p2} ), //input [21:0] - not used {11'b0,txln_p0} .tx_std ( tx_std_p2 ), // tx_std_p0 //tx outputs .sdi_tx ( hsma_tx_p[0] ), //output [0:0] .gxb_tx_clkout ( tx_p2_clkout ), //output [0:0] .tx_status ( tx_p2_stat ), //output [0:0] - not used //rx inputs .rx_serial_refclk ( gxb_refclk ), //input .sdi_rx ( hsma_rx_p[0] ), //input [0:0] //rx outputs //.rxdata ( sdi_rx_data), //output [19:0] //.rx_data_valid_out (sdi_rx_data_valid_out ), //output [1:0] .rxdata ( rx_p2_data ), //output [19:0] .rx_data_valid_out ( rx_p2_data_valid ), //output [1:0] .rx_clk ( rx_p2_clk ), //output -same as "port1_rx_clk" .rx_status ( rx_p2_status ), //output [10:0] .rx_ln ( rx_p2_ln ), //output [21:0] .rx_std ( rx_p2_std ), //output [1:0] //not used .rx_anc_data ( rx_p2_anc_d ), //output [19:0] .rx_anc_valid ( rx_p2_anc_v ), //output [3:0] .rx_anc_error ( rx_p2_anc_er ), //output [3:0] .rx_std_flag_hd_sdn ( sdi_rx_std_flag_hd_sdn_0 ), //output [0:0] .rx_F ( rx_p2_F ), //output [1:0] .rx_V ( rx_p2_V ), //output [1:0] .rx_H ( rx_p2_H ), //output [1:0] .rx_AP ( rx_p2_AP ), //output [1:0] // reconfig inputs .sdi_reconfig_clk ( sdi_reconfig_clk ), //input .sdi_reconfig_togxb ( sdi_reconfig_togxb ), //input [3:0] .sdi_reconfig_done ( multi_reconfig_done[0] ), //input //reconfig outputs .sdi_reconfig_fromgxb ( rc_fromgxb[16:0] ), //output 16 bits .sdi_start_reconfig ( sdi_start_reconfig[0] ) //output ); Why is it not output?
