14 years agoArria II GX kit + SDI + VIP , only CVI->CVO, CVO no output
Arria II GX kit + SDI + VIP , only CVI->CVO, CVO no output. There are is_clk,is_data,vid_clk,vid_data,vid_data_input,no av_readdata,av_writedata,is_active_line_count_f0,is_active_line_count_f1....
14 years agoThe screenshot doesn't give any information, since You've not expanded all the modules and connections are not shown. E.g. now it shows that pipeline bridge slave is not connected.
vid_std shows video standard and has nothing to do with the stream itself.
