14 years agoArria II GX kit + SDI + VIP , only CVI->CVO, CVO no output
Arria II GX kit + SDI + VIP , only CVI->CVO, CVO no output. There are is_clk,is_data,vid_clk,vid_data,vid_data_input,no av_readdata,av_writedata,is_active_line_count_f0,is_active_line_count_f1....
14 years agousing SignalTap,sopc_system:sopc_system_inst|alt_vipitc111_IS2Vid:sdi_out_1|vid_std = 0. The CVO doesn't work normally,is right?
