14 years agoArria II GX kit + SDI + VIP , only CVI->CVO, CVO no output
Arria II GX kit + SDI + VIP , only CVI->CVO, CVO no output. There are is_clk,is_data,vid_clk,vid_data,vid_data_input,no av_readdata,av_writedata,is_active_line_count_f0,is_active_line_count_f1....
14 years agoPlease check Qsys.bmp.
CVI Parameters: Bits per pixel per color plane:10bits Number of color planes:2 Color plane transmission format:Paraller Field order:Field 0 first Sync signals:Embedded in video Allow corlor planes in sequence input use vid_std bus width of vid_std bus: 3 bits Extract ancillary packets Interlaced widh:1920 pixels Height-frame/field 0:540 Height-field1:540 Pixel FIFO size:4000 use control port Generate synchronization outputs:Yes CVO Parameters: image width/Active pixels: 1920 image height/Active lines:1080 Bits per pixel per color plane: 10 Number of color planes:2 Color plane transmission format:Paraller Allow output of channels in sequence Interlaced video Synces signals:Embedded in video Active picture line:21 Ancillary packet insertion line:0 Horizontal blanking:280 Verticla blanking:22 Horizontal sync:0 horizontal front porch:0 Horizontal back porch:0 Vertical sync:0 Vertical front porch:0 Vertical back porch:0 F rising edge line:564 F falling edge line:1 Vertical blanking rising edge line:561 Ancillary packet insetion line:0 Vertica balnking:23 Vertical sync:0 verticl front porch:0 Vertical back porch:0 Pixel fifo size :1920 fifo level at which to start ouput:1919 use control port Accept synchronization ouputs Runtime configurable video modes:3 width of vid_std bus:3
