14 years agoArria II GX Devkit TSE RGMII Help
Hi all,
I've been struggling to get the ethernet port working on the Arria II devkit (after getting flash, DDR2, and DDR3 working). I am mimicking the code found in bts_config, but using vhdl, qsys, and quartus 11.0sp1. Just aiming to get the simple socket server running. The pre-loaded webserver works on power-up, so the HW is good. Here is the startup output Simple Socket on my fpga:
INFO : TSE MAC 0 found at address 0x00001400
INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group
INFO : PHY - Automatically mapped to tse_mac_device
INFO : PHY - Restart Auto-Negotiation, checking PHY link...
INFO : PHY - Auto-Negotiation PASSED
MARVELL : Mode changed to RGMII/Modified MII to Copper mode
MARVELL : Enable RGMII Timing Control
MARVELL : PHY reset
INFO : PHY - Checking link...
INFO : PHY - Link not yet established, restart auto-negotiation...
INFO : PHY - Link established
INFO : PHY - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 0.0.0.0
DHCP timed out, going back to default IP address(es) It appears that the dhcp request is not being transmitted. The ENET TX led blinks a few times during this process, so there is at least an attempt to transmit the packet. After scouring the forums/web, I have not been able to nail down the issue. Issues I have noticed in old posts that may or may not affect 11.0sp1: - The PHY expects clock to be skewed, but this can be fixed by writing to a PHY reg with MDIO. It appears "Enable RGMII Timing Control" is doing that.
- Simple socket must be modified for RGMII.
- RGMII does not support 10/100 speeds.
Hello, Hendryjh!
Did you get it project working? - Altera_Forum
--- Quote Start --- Hello, Hendryjh! Did you get it project working? --- Quote End --- Yes, by using the AN647 Arria II GX example project http://www.altera.com/literature/an/an647_reference_design_aii_rgmii.zip (http://www.altera.com/literature/an/an647_reference_design_aii_rgmii.zip) If you have the 260 devkit, you will need to change the device in the quartus. - Altera_Forum
Thanks, Hendryjh.
I have a 125 devkit. I know this app. note, but i find qsys or sopc project that include all peripherial components installed on board (ddr2, ddr3, eth, hsma, maybe pcie). Did you know same projects? At this time i try to build same project manually (exclude pcie).
