14 years agoArria II GX Devkit TSE RGMII Help
Hi all, I've been struggling to get the ethernet port working on the Arria II devkit (after getting flash, DDR2, and DDR3 working). I am mimicking the code found in bts_config, but using vhdl,...
14 years ago --- Quote Start --- Hello, Hendryjh! Did you get it project working? --- Quote End --- Yes, by using the AN647 Arria II GX example project http://www.altera.com/literature/an/an647_reference_design_aii_rgmii.zip (http://www.altera.com/literature/an/an647_reference_design_aii_rgmii.zip) If you have the 260 devkit, you will need to change the device in the quartus.
