diddi1057
5 years agoArria 10 transceiver ATX PLL unlocked, when reference clock not present during device configuration
Hi all,
please refer to attachment pdf ....
- 5 years ago
good news:
1. I have successfully simulated design in Modelsim -> ATX PLL relocked after REFCLK is present ->o.k.
2. I have successfully downloaded design to hardware -> ATX PLL relocked after REFCLK is present ->o.k.
Thank's for your advice!
diddi1057
CheepinC_altera
5 years agoHi,
Would you mind to share with simulation which could be directly simulated in Modelsim ie using msim_setup.tcl without going through native link. This would be helpful to facilitate further debugging. Thank you.
- diddi10575 years ago
attached project using msim_setup.tcl .
Created /mentor/test_atx_pll_no_lock.do -> Adapt QSYS_SIMDIR
