Arria 10 transceiver ATX PLL unlocked, when reference clock not present during device configuration
- 5 years ago
good news:
1. I have successfully simulated design in Modelsim -> ATX PLL relocked after REFCLK is present ->o.k.
2. I have successfully downloaded design to hardware -> ATX PLL relocked after REFCLK is present ->o.k.
Thank's for your advice!
diddi1057
Thanks for your update. Your steps tally with those described in the user guide. I checked with register map and do not spot any anomaly. Just to check with you when you are doing the same steps in hardware, do you see the pll_cal_busy go high after triggering recalibration?
Can you share with me a simple test design with one channel Native PHY + ATX PLL + reset controller which could replicate your observation in Modelsim? I would like to further look into it.
Chee Pin
- diddi10575 years ago
thanks for your answer. Will try do give you the required info next Monday!
attached the simple simulation project with one channel Native PHY + ATX PLL + reset controller. Please refer to atx_pll_simu.pdf inside project for instruction.
I have to check again the same steps in hardware, if pll_cal_busy go high after triggering recalibration ...
Best regards
diddi1057
