Arria 10 PCIe SRIOV IP
Hello ,
I am using the SRIOV PCIe IP core. When I write 32-bit DWs into the host memory from the endpoint, some of them get stuck. For example , I see the write request at the correct address go out on the bus, but the host memory does not show these changes until more writes are performed. So if its the last write to the host software, this will never show up. I am using a dma_alloc_coherent for all shared space between FPGA and system software. Does anybody know what could be causing these issues. Seems very strange and I cannot pinpoint an issue.
Thank you!
Solved issues thanks for the reply. The tx empty encoding was incorrect on one of the writes.
- KhaiChein_Y_Intel
What device you are using? Have you tried checking using signal tap? Are all the signals correct from the STP?
KhaiY
- KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
- agula
- mark_lee
Hi agula
do you have the a10 sriov driver for linux ?
