agula
5 years agoArria 10 PCIe SRIOV IP
Hello ,
I am using the SRIOV PCIe IP core. When I write 32-bit DWs into the host memory from the endpoint, some of them get stuck. For example , I see the write request at the correct address go o...
- 5 years ago
Solved issues thanks for the reply. The tx empty encoding was incorrect on one of the writes.
KhaiChein_Y_Intel
5 years agoHi,
What device you are using? Have you tried checking using signal tap? Are all the signals correct from the STP?
KhaiY
