Arria 10 Native Transceiver PHY 10GBASE-R w/KR FEC Clocks
- 5 years ago
As I understand it, you have some inquiries related to the A10 Native PHY in 10GBaseR mode. Please see my responses as following:
1) Is the tx_pma_div_clkout destined to be used for my custom FPGA
fabric (MAC, data preprocessing, ...) and the tx_coreclkin?
[CP] Yes, your understanding is correct. This clock is of 156.25MHz which is to use with the XGMII interface and connect to xgmii_tx_clk/xgmii_rx_clk
2) Shall I activate the rx_pma_div_clkout to do the same here? If so,
why is it not activated by default?
[CP] You can use tx_pma_div_clkout for xgmii_tx/rx_clk. So, this clock is not used by default.
3) If the answers to 1) and 2) are yes, what is the purpose of the
tx_clkout and rx_clkout?
[CP] These are clocks used to clock in the internal blocks of the XCVR channels.
Chee Pin
Chee Pin
- FHint5 years ago
thank you a lot for the answer! Then I'll just use the tx_pma_div_clkout for the XGMII interface and the tx_coreclkin/ rx_coreclkin.
Regarding question number 3 and just for my better understanding: Is there any purpose to the 161 MHz tx_clkout and rx_clkout outside of the Transceiver PHY?
Best Regards
Florian
