Arria 10 Native Transceiver PHY 10GBASE-R w/KR FEC Clocks
I am currently struggling with the Arria 10 Native Transceiver configured with the 10GBASE-R /wKR FEC preset.
I am using the following document as reference: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/ug_arria10_xcvr_phy.pdf
In Figure 57 you can see that the tx_clkout and rx_clkout have 161.1 MHz and that the tx_coreclkin and rx_coreclkin are meant to have 156.25 MHz (from XGMII).
Now with the above mentioned preset the tx_pma_div_clkout is configured as 5156.25/33 = 156.25 MHz. The rx_pma_div_clkout is disabled.
My questions are:
1) Is the tx_pma_div_clkout destined to be used for my custom FPGA fabric (MAC, data preprocessing, ...) and the tx_coreclkin?
2) Shall I activate the rx_pma_div_clkout to do the same here? If so, why is it not activated by default?
3) If the answers to 1) and 2) are yes, what is the purpose of the tx_clkout and rx_clkout?
A similar question has already been asked here but unfortunately it wasn't answered.
https://community.intel.com/t5/Programmable-Devices/Arria-10-Native-Transceiver-PHY-10GBASE-R/m-p/16523
Thank you in advance!
Best Regards
As I understand it, you have some inquiries related to the A10 Native PHY in 10GBaseR mode. Please see my responses as following:
[CP] Yes, your understanding is correct. This clock is of 156.25MHz which is to use with the XGMII interface and connect to xgmii_tx_clk/xgmii_rx_clk
[CP] You can use tx_pma_div_clkout for xgmii_tx/rx_clk. So, this clock is not used by default.
[CP] These are clocks used to clock in the internal blocks of the XCVR channels.
Chee Pin
- CheepinC_altera
Chee Pin
- FHint
thank you a lot for the answer! Then I'll just use the tx_pma_div_clkout for the XGMII interface and the tx_coreclkin/ rx_coreclkin.
Regarding question number 3 and just for my better understanding: Is there any purpose to the 161 MHz tx_clkout and rx_clkout outside of the Transceiver PHY?
Best Regards
Florian
- CheepinC_altera
Regarding the latest inquiry on the tx/rx_clkout, I am not sure about the specific usage for user in core since I am not really a design specialist. Sorry for the inconvenience.
- CheepinC_altera
I believe the initial inquiry has been addressed. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
