8 years agoArria 10 GX Dev Kit - EMIF Controller Avalon Memory Mapped Slave
I am designing user logic to access DDR4 Memory on Arria 10 GX FPGA Development Kit. I instantiated EMIF in Qsys. It has following parameters: DQ width: 72 Row address width: 15 Column address width: 10 Bank address width: 2 Bank group width: 1 Now, ctrl_amm_0 (Avalon Memory Mapped Slave) for EMIF IP has following signals: address: 25 burstcount: 7 byteenable: 72 read: 1 readdata: 576 readdatavalid: 1 ready : 1 write: 1 writedata : 576 I can understand larger readdata/writedata size as it works at quarter rate. But what I do not understand is addressing method. Slave only expects 25 bits as address which is sum of row and column address. How do I specify bank address and bank group? Thanks and Regards, Parthiv2 Replies
Hmm. What do you have the Address Ordering option set to on the Controller tab in the parameter editor?
Address ordering is Chip-Row-Bank-Col-BG. Thank you...
