8 years agoArria 10 DDR3 with Bank 3G and 3H
Hi all, I have a question about the bank usage for DDR3 memory in the Arria 10. I'm using the following hardware: Arria 10: 10AX115R3F40E2SG DDR3 memory: Micron MT41J128M16HA-187E:D ...
8 years agoThank for your answer.
Concerning your suggestion, what does happen for the removed pins? BTW, after some iterations, I managed it. What I did is to use bank 3H for both DQ but when I used 1-11 and 12-23, the Fitter did not pass but when I used 12-23 and 36-47, the Fitter finished w/o error. regards, Junichi
