8 years agoArria 10 DDR3 with Bank 3G and 3H
Hi all, I have a question about the bank usage for DDR3 memory in the Arria 10. I'm using the following hardware: Arria 10: 10AX115R3F40E2SG DDR3 memory: Micron MT41J128M16HA-187E:D ...
8 years agoTried to remove all location assignment for the DQ/DQS/DM (x8) in bank 3G.
The only force one DQS pin with constraint as below see if you can fit the DQ/DQS/DM (x8) in bank 3G. set_location_assignment IOBANK_3G -to <dqs pin name> (This message was posted on behalf of Intel Corporation)
