API calls failed while running PCIe DMA transfer example design
Hi Sijith,
The API call failure I mentioned before is that happened when Adzim provided some modified VHDL code for the PCIe_DMA transfer example design + Avalon FIFO + counter (basically he tested altered the signal connectivity). While programmed with that modified design, I got API call failure.
>> Can you file another forum case and select the "catagory" as EMif so that Adzim can take loop back on the API failure ?
Wincent_Intel
Hi
A fews follow up had been make.
We have not hear from you and this Case is idling. It is not recommended to idle for too long.
Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
