API calls failed while running PCIe DMA transfer example design
Sorry I am a little bit lost.
Previously when I talking with Sijith, he mention that follow the PCIe_ddr4 design. the DMA APi call to read data is fails.
Also found that API call failure.
Then we move to simulation and check if the same behavior happen or not.
If this is emif simulation, you may refer to https://www.youtube.com/watch?v=iCr-0eOwo9o&ab_channel=IntelFPGA
And see if you are able to seeing something similar as the hardware or not.
Last I would like to confirm back with you, is this is a PCIe design or EMIf design ?
the error is happen in emif part of PCIe HIP part ?
Wincent_Intel
Hello Wincent,
Then we move to simulation and check if the same behavior happen or not. And see if you are able to seeing something similar as the hardware or not.
This is still what we want to do. But we dont have all the parts for it. I am going to review the video and get back to you.
We are lost in this part to identify where this is happening. I have taken up Simulation efforts. This is Terasic's PCIe_DDR example. It has a PCIe Hard IP as well as DDR emif. Please see attached Image.
Best,
Manish
