Sijith
3 years agoAPI calls failed while running PCIe DMA transfer example design
Hi, I was working the PCIe DMA transfer example design for Arria 10. I have added a counter custom IP which counts upto 1000, and An Avalon FIFO IP with the design. My intention is to write the data...
Wincent_Altera
3 years agoHi Sijith,
- Did you able to capture the LTSSM signal from Signal tap ? just to ensure the PCIe is able to link up.
- Did you connect the PCIe external power connector to 6-pin 12V DC power connector in the FPGA to avoid FPGA damage due to insufficient power ?
Wincent_Intel
- Wincent_Altera3 years ago
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket
Wincent_Intel
- treble993 years ago
Hello Wincent,
Please give me until Monday to try all your recommendations. Please do not close the ticket until then.
Manish
