Sijith
3 years agoAPI calls failed while running PCIe DMA transfer example design
Hi, I was working the PCIe DMA transfer example design for Arria 10. I have added a counter custom IP which counts upto 1000, and An Avalon FIFO IP with the design. My intention is to write the data...
treble99
3 years agoHello Wincent,
I read through both documents but some things are still not clear. I also do not have experience in simulating BFMs before.
1. I see a set of BFMs but How do i drive signals? I want to verify that data is being read and written to each DDR a and b.
what should I add in The generated tcl script msim_setup.tcl
2. I read the solution guide and it talks about receiving a successful message after `run -all`, I let it run for a really long time and I do not get any message and my log file is also empty.
Attaching screenshots.
Appreciate the help!
Thank you,
Manish
