Sijith
3 years agoAPI calls failed while running PCIe DMA transfer example design
Hi, I was working the PCIe DMA transfer example design for Arria 10. I have added a counter custom IP which counts upto 1000, and An Avalon FIFO IP with the design. My intention is to write the data...
Sijith
3 years agoHi,
I don't believe its a compilation failure, as the counter + FIFO + DMA transfer design are compiling without any error. I would like to report that now I am not getting the API failure that I mentioned before. I could resolve that by the driver re-installation.
But I still not able to get the counter data (at the DDR4) that I am creating in the counter. A video of output is attached. the data I am expecting at the DDR4 is the counter output that counts from 0. It would be great if you could have a look to see what can cause this. If needed I can give access to my working directory to you.
Thank you.
