APB interface
I am trying to configure third party IP from my platform designer system. This IP uses APB interface. I wanted to know if I can use build in bridge inorder to config this IP from NIOS?
Elad Rotem
- WZ2
Hi Elad,
Do u mean u wanna use platform designer to connect the nois and your IP by APB interface?
WZ
- Elad0708
Thank you for your replay.
Yes. The third-party IP will have its own address map.
Elad
- tehjingy_Altera
Hi Elad
Unfortunately the NiosV do not have APB interface, there is an AXI4 interface for the NiosV.
You could try creating your own APB to AXI4 bridge for the connection.
If your IP could connect through AXI4 you can connect it to the DataManager connector of the NiosV in the Platform Designer.
You could refer to the example design below. The PIO IP is connected to the NiosV through AXI4.
Jingyang, Teh
Jingyang, Teh
- tehjingy_Altera
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
- Elad0708
Thanks for your replay and sorry for the slow response (been on vacation:)).
What if I want to write my own component with specific address mapping. What should I do ?
Elad Rotem
