10 years agoaltsyncram simulating, data changes on failing edge
I'm simulating altsyncram with Modelsim for Cyclone V.
I use altsyncram instantiated as ROM.INCLUDE "altsyncram.inc";
FUNCTION mROM_256x18_1port( clock, address ) returns( q );
PARAMETERS ( FILE_MIF = "FILE.MIF" );
SUBDESIGN mROM_256x18_1port
address : INPUT;
clock : INPUT;
q : OUTPUT;
VARIABLE
altsyncram_component : altsyncram WITH (
ADDRESS_ACLR_A = "NONE",
CLOCK_ENABLE_INPUT_A = "BYPASS",
CLOCK_ENABLE_OUTPUT_A = "BYPASS",
INIT_FILE = FILE_MIF,
INTENDED_DEVICE_FAMILY = "Cyclone V",
LPM_HINT = "ENABLE_RUNTIME_MOD=NO",
LPM_TYPE = "altsyncram",
NUMWORDS_A = 256,
OPERATION_MODE = "ROM",
OUTDATA_ACLR_A = "NONE",
OUTDATA_REG_A = "UNREGISTERED",
WIDTHAD_A = 8,
WIDTH_A = 18,
WIDTH_BYTEENA_A = 1
BEGIN
q = altsyncram_component.q_a;
altsyncram_component.clock0 = clock;
altsyncram_component.address_a = address;
END;
I've create simple project for testing the ROM only. Simple SystemVerilog file to compile parametrized ROM to SystemVerilog netlist to simulate with Modelsim: module ROM_Coeff_AHDL(address,
data_out,
clock
input wire address;
output reg data_out;
input wire clock;
mROM_256x18_1port# (
.FILE_MIF ("filt_triangle.mif")
) inst_mROM_256x18_1port
.clock (clock),
.address (address),
.q (data_out)
endmodule
Testbench. Incrementing address with every clock rising edge: `timescale 1 ps/ 1 ps
module memory_short_tb();
wire address;
wire data_out;
reg clk;
reg addr_counter;
ROM_Coeff_AHDL U_memory(
.address (address),
.data_out (data_out),
.clock (clk)
initial begin
clk = 0;
addr_counter = 0;
end
always# 1 clk = ~clk;
always @ (posedge clk) begin
addr_counter++;
end // always
assign address = addr_counter;
endmodule And the result : http://www.alteraforum.com/forum/attachment.php?attachmentid=12140&stc=1 Data changes on failing edge. But the datasheet https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram_rom.pdf says "Rising clock edges" on the page 3-2 . Why data changes on failing edge? Has anybody get the same issue? What is wrong? How to fix issue?2 Replies
the DSP Builder Advanced Blockset's Handbook mentioned an example of FFT known as "parallel floating-point fft" and has as a model file "demo_parallel_fpfft.mdl"
and a second one named Variable-Size Floating-Point FFT,[/B] its model file is demo_fpvfft.mdl. Could anyone give me an explanation of what these designs examples demonstrate ?[/B]
After changing
toalways# 1 clk = ~clk;
Data bus updates 1 ps after rising edge of clock.always# 10 clk = ~clk;
